Introduzione
Are your selfies not showing up? Replace your front camera to see how beautiful you are.
This guide will require soldering equipment and skill.
Before disassembling your LeapPad, ensure your device is shut off. Push outward on the plastic side panels to remove and reveal battery.
  • Before disassembling your LeapPad, ensure your device is shut off.
  • Push outward on the plastic side panels to remove and reveal battery.
  • The panels should detach fully from the main device.
Aggiungi Commento
Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser. Remove all four AA alkaline batteries from the device. Remove all four AA alkaline batteries from the device.
  • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
  • Remove all four AA alkaline batteries from the device.
Aggiungi Commento
This step will void your device warranty. Remove the following screws securing the back cover to the main device:
  • This step will void your device warranty.
  • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
Aggiungi Commento
Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device. Move the plastic opening tool around the perimeter of the LeapPad2. Lift up and remove the rear case from the tablet.
  • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
  • Move the plastic opening tool around the perimeter of the LeapPad2.
  • Lift up and remove the rear case from the tablet.
  • A butter knife can help when prying the device.
Aggiungi Commento
Remove the following screws securing the front cover to the main device: Three 6.0 mm Phillips screws
  • Remove the following screws securing the front cover to the main device:
    • Three 6.0 mm Phillips screws
    • Three 7.0 mm Phillips screws
    • Three 7.0 mm Phillips screws (bulkier screw head than other 7.0 mm Phillips screws)
      • The white plastic component holding the speaker must be removed to reach the third 7.0 mm Phillips screw. Refer to Step 2.
Aggiungi Commento
Unscrew the white plastic piece to expose the third 7.0 mm Phillips screw mentioned. Unscrew the white plastic piece to expose the third 7.0 mm Phillips screw mentioned.
  • Unscrew the white plastic piece to expose the third 7.0 mm Phillips screw mentioned.
Aggiungi Commento
When unscrewing the game cartridge screws, you will find a loose black plastic component underneath the game cartridge. Use tweezers to remove the piece.
  • When unscrewing the game cartridge screws, you will find a loose black plastic component underneath the game cartridge.
  • Use tweezers to remove the piece.
  • In case the piece falls out unexpectedly, refer to this step to make sure you put this piece back in place during the reassembly of your device.
Aggiungi Commento
Desolder the through hole-components in power plugs on both sides of the device where the batteries were once connected. Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
  • Desolder the through hole-components in power plugs on both sides of the device where the batteries were once connected.
  • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
  • For proper soldering and desoldering techniques reference How To Solder and Desolder Connections.
  • Soldering requires the iron to be at hot temperatures and can cause burns. Wear safety glasses as needed.
  • Be extremely careful with the cables in this step as they could melt, burn, or break.
Aggiungi Commento
Pry the power cables from the device using your fingers or tweezers. Now you should be able to lift up the front cover, leaving you with the motherboard and screen.
  • Pry the power cables from the device using your fingers or tweezers.
  • Now you should be able to lift up the front cover, leaving you with the motherboard and screen.
Aggiungi Commento
Lift the screen from the motherboard by pulling the board out from the three metal tabs. Do not be too aggressive when separating the components, as the parts are still connected. Do not be too aggressive when separating the components, as the parts are still connected.
  • Lift the screen from the motherboard by pulling the board out from the three metal tabs.
  • Do not be too aggressive when separating the components, as the parts are still connected.
Aggiungi Commento
Separate the screen from the motherboard and lay the device's components flat open like a book.
  • Separate the screen from the motherboard and lay the device's components flat open like a book.
Aggiungi Commento
Peel off tape covering the camera's connection ribbon to the circuit. Peel off tape covering the camera's connection ribbon to the circuit.
  • Peel off tape covering the camera's connection ribbon to the circuit.
Aggiungi Commento
To safely remove the ribbon cable, you must first pull up the retaining flap.
  • To safely remove the ribbon cable, you must first pull up the retaining flap.
  • Failing to do this step could result in damage to the cable and/or connector.
Aggiungi Commento
Gently pull outward, to remove the ribbon from the socket on the circuit board.
  • Gently pull outward, to remove the ribbon from the socket on the circuit board.
  • If the flap is up as shown in the picture, no force should be required to remove the ribbon cable.
Aggiungi Commento
Conclusione
Nupur Garg
Membro da: 12/04/2014
840 Reputazione
7 Guide realizzate
Cal Poly, Team 8-10, Regan Spring 2014 Membro di Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 355
