Salta al contenuto principale
LeapFrog LeapPad2 Explorer Back Cover Replacement
Cosa ti serve
  1. LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: passo 1, immagine 1 di 2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: passo 1, immagine 2 di 2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Back Cover Replacement: passo 2, immagine 1 di 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: passo 2, immagine 2 di 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: passo 2, immagine 3 di 3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: passo 3, immagine 1 di 2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: passo 3, immagine 2 di 2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Back Cover Replacement: passo 4, immagine 1 di 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: passo 4, immagine 2 di 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: passo 4, immagine 3 di 3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
Conclusione
Nupur Garg
Membro da: 04/12/14
867 Reputazione
7 Guide realizzate
Cal Poly, Team 8-10, Regan Spring 2014 Membro di Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,405
