Salta al contenuto principale
Lasko 2002W Motor Replacement
Cosa ti serve
  1. Lasko 2002W Motor Replacement, Remove cover: passo 1, immagine 1 di 1
    • Remove the front cage from the fan, exposing the screws.
  2. Lasko 2002W Motor Replacement, Remove screws: passo 2, immagine 1 di 1
    • Remove the 3 screws holding the fan on to the motor housing using a 3/16" philips head screw driver. The length of the screwdriver does not matter.
  3. Lasko 2002W Motor Replacement, Remove motor screws: passo 3, immagine 1 di 1
    • Remove the screws holding the motor onto the fan using the same 3/16" phillips head screwdriver. There are two screws.
    • Once removed, remove the metal part the screws were holding to the motor.
  4. Lasko 2002W Motor Replacement, Remove old motor.: passo 4, immagine 1 di 1
    • Remove the old motor from the fan. No tools are required. The motor can simply be pulled out.
  5. Lasko 2002W Motor Replacement, Place new motor in motor housing.: passo 5, immagine 1 di 1
    • Now that the old motor is removed, a new motor can be placed in the motor housing.
Conclusione
Altre 9 persone hanno completato questa guida.
elsa
Membro da: 10/11/14
382 Reputazione
1 Guida realizzata
USF Tampa, Team 1-39, Donnelly Fall 2014 Membro di USF Tampa, Team 1-39, Donnelly Fall 2014
USFT-DONNELLY-F14S1G39
1 Membro
1 Guida realizzata
Un commento
What is the part number for replacement motor? Where do you get it?
Paul Dias - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 32
Tutti i Tempi: 3,524
