Salta al contenuto principale
LG env2 vx9100 Inside Keyboard Replacement
Cosa ti serve
  1. LG env2 vx9100 Inside Keyboard Replacement, Battery: passo 1, immagine 1 di 3 LG env2 vx9100 Inside Keyboard Replacement, Battery: passo 1, immagine 2 di 3 LG env2 vx9100 Inside Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Inside Keyboard Replacement, Back Panel: passo 2, immagine 1 di 2 LG env2 vx9100 Inside Keyboard Replacement, Back Panel: passo 2, immagine 2 di 2
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Inside Keyboard Replacement: passo 3, immagine 1 di 2 LG env2 vx9100 Inside Keyboard Replacement: passo 3, immagine 2 di 2
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Inside Keyboard Replacement: passo 4, immagine 1 di 2 LG env2 vx9100 Inside Keyboard Replacement: passo 4, immagine 2 di 2
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: passo 5, immagine 1 di 3 LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: passo 5, immagine 2 di 3 LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: passo 5, immagine 3 di 3
    • Locate the silver strip connected to the logic board. The silver strip is closest to the bottom hinge of the phone.
    • Wedge the plastic opening tool in between the silver strip and the logic board.
    • Lift the plastic opening tool to separate the silver strip from the logic board.
  6. LG env2 vx9100 Inside Keyboard Replacement: passo 6, immagine 1 di 2 LG env2 vx9100 Inside Keyboard Replacement: passo 6, immagine 2 di 2
    • Wedge the plastic opening tool in between the logic board and the phone.
    • Lift the plastic opening tool to separate the logic board from the phone.
  7. LG env2 vx9100 Inside Keyboard Replacement: passo 7, immagine 1 di 2 LG env2 vx9100 Inside Keyboard Replacement: passo 7, immagine 2 di 2
    • Locate the back of the inside keyboard.
    • Take out the inside keyboard. You may need to use your fingernail to pull one of the corners up.
Conclusione
Cal Poly, Team 16-55, Forte Fall 2012 Membro di Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 832
