Introduzione
In this guide you will be removing the front panel from the rest of the phone to access the front keyboard.
Parti
Nessuna parte richiesta.
Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire. Place the phone facedown on the table. Use your fingernail (or a small screw driver) to pull down the tab below the battery.
  • Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
  • Place the phone facedown on the table.
  • Use your fingernail (or a small screw driver) to pull down the tab below the battery.
  • Lift the battery out.
Aggiungi Commento
Locate the five rubber covers on the back panel of the phone. Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  • Locate the five rubber covers on the back panel of the phone.
  • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
Aggiungi Commento
Locate the six 2.5mm screws on the back panel of the phone. Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  • Locate the six 2.5mm screws on the back panel of the phone.
  • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
Aggiungi Commento
Locate the seam around the edge of the phone. Insert the plastic opening tool into the seam and pry gently to release the tabs.
  • Locate the seam around the edge of the phone.
  • Insert the plastic opening tool into the seam and pry gently to release the tabs.
  • Work your way around the phone until all tabs are released.
  • Remove the back panel of the phone.
Aggiungi Commento
Locate the rubber covers at the top two corners of the inside of the phone. Use the metal probe to remove the rubber covers to reveal the 2.5mm screws.
  • Locate the rubber covers at the top two corners of the inside of the phone.
  • Use the metal probe to remove the rubber covers to reveal the 2.5mm screws.
Aggiungi Commento
Locate the 2.5mm screws that were underneath the rubber covers. Use a #00 Phillips screwdriver to remove both 2.5mm screws.
  • Locate the 2.5mm screws that were underneath the rubber covers.
  • Use a #00 Phillips screwdriver to remove both 2.5mm screws.
Aggiungi Commento
Locate the two 2.5mm screws at the bottom two corners of the inside of the phone. These screws will not be visible or accessible unless the 2 sides of the phone are at approximately 90 degrees relative to each other.
  • Locate the two 2.5mm screws at the bottom two corners of the inside of the phone.
  • These screws will not be visible or accessible unless the 2 sides of the phone are at approximately 90 degrees relative to each other.
Aggiungi Commento
Locate the crease that travels all around the edge of the phone. Wedge the plastic opening tool in the crease and move it along each edge of the phone.
  • Locate the crease that travels all around the edge of the phone.
  • Wedge the plastic opening tool in the crease and move it along each edge of the phone.
  • Separate the front panel from the rest of the phone.
  • Be careful not to damage the orange ribbon that connects to the logic board through the hinge in the phone. If the ribbon is damaged, the phone will not function properly.
  • Open the phone to reveal the inside monitor.
Aggiungi Commento
Locate the two 2.5mm screws to the right of the screen (on the photograph shown they are at the bottom). Use a #00 Phillips screwdriver to remove each 2.5mm screw. Using your hands separate the front panel from the phone by carefully pulling it straight off.
  • Locate the two 2.5mm screws to the right of the screen (on the photograph shown they are at the bottom).
  • Using your hands separate the front panel from the phone by carefully pulling it straight off.
Aggiungi Commento
Place the front panel so that the buttons face upwards. Push on the buttons to remove the keyboard from the front cover.
  • Place the front panel so that the buttons face upwards.
  • Push on the buttons to remove the keyboard from the front cover.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Reed Williston
Membro da: 26/09/2012
22 Reputazione
14 Guide realizzate
Cal Poly, Team 16-55, Forte Fall 2012 Membro di Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 600
