Salta al contenuto principale
LG Xenon Front Case/Screen Replacement
Cosa ti serve
  1. LG Xenon Front Case/Screen Replacement, Back Case: passo 1, immagine 1 di 1
    • Turn the phone over so the back side is facing you.
  2. LG Xenon Front Case/Screen Replacement: passo 2, immagine 1 di 2 LG Xenon Front Case/Screen Replacement: passo 2, immagine 2 di 2
    • Placing your thumb on the bottom of the phone, apply pressure to the small ridge in the middle of the phone and push upward towards the camera.
    • The back casing should slide off.
  3. LG Xenon Front Case/Screen Replacement, Battery: passo 3, immagine 1 di 2 LG Xenon Front Case/Screen Replacement, Battery: passo 3, immagine 2 di 2
    • Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
    • The battery should easily fall out after the top of the battery has been pulled out.
  4. LG Xenon Front Case/Screen Replacement, Motherboard: passo 4, immagine 1 di 2 LG Xenon Front Case/Screen Replacement, Motherboard: passo 4, immagine 2 di 2
    • Unscrew the six 2.4mm Phillips #00 screws (three on the left and three on the right of the phone) to remove the inner back case.
  5. LG Xenon Front Case/Screen Replacement: passo 5, immagine 1 di 1
    • Once all six screws are removed, use the plastic opening tool to carefully pry apart the inner back case. Push the plastic tool underneath the case. Carefully push upward, with the tool, while moving it around the case.
  6. LG Xenon Front Case/Screen Replacement: passo 6, immagine 1 di 2 LG Xenon Front Case/Screen Replacement: passo 6, immagine 2 di 2
    • Remove the camera, lock, and volume buttons from the side of the phone.
  7. LG Xenon Front Case/Screen Replacement: passo 7, immagine 1 di 2 LG Xenon Front Case/Screen Replacement: passo 7, immagine 2 di 2
    • Carefully remove the two 3mm Phillips #00 screws (one on the top and one on the bottom) that are attaching the motherboard to the phone.
  8. LG Xenon Front Case/Screen Replacement: passo 8, immagine 1 di 2 LG Xenon Front Case/Screen Replacement: passo 8, immagine 2 di 2
    • For this next step, carefully lift and remove the motherboard.
    • A connector cable will still be connected to the motherboard upon removing it.
    • Damage to the connector cable will permanently disable phone.
  9. LG Xenon Front Case/Screen Replacement: passo 9, immagine 1 di 2 LG Xenon Front Case/Screen Replacement: passo 9, immagine 2 di 2
    • Carefully unclip the silver metallic tab from the motherboard.
  10. LG Xenon Front Case/Screen Replacement: passo 10, immagine 1 di 2 LG Xenon Front Case/Screen Replacement: passo 10, immagine 2 di 2
    • Once the cable is removed, you have successfully disassembled the motherboard of your phone.
  11. LG Xenon Front Case/Screen Replacement, Keyboard: passo 11, immagine 1 di 1
    • Turn the motherboard over and carefully remove the keypad from the motherboard.
    • The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
  12. LG Xenon Front Case/Screen Replacement, LCD: passo 12, immagine 1 di 1
    • After removing the motherboard and keyboard, unscrew eight 1.6mm Phillips #00 screws in the middle of the phone.
  13. LG Xenon Front Case/Screen Replacement: passo 13, immagine 1 di 1
    • Remove slider piece.
    • Pay close attention that you don’t lose the spring.
    • Carefully remove the spring.
  14. LG Xenon Front Case/Screen Replacement: passo 14, immagine 1 di 2 LG Xenon Front Case/Screen Replacement: passo 14, immagine 2 di 2
    • Remove six 2.25mm Phillips #00 screws along the outside of the case.
  15. LG Xenon Front Case/Screen Replacement: passo 15, immagine 1 di 2 LG Xenon Front Case/Screen Replacement: passo 15, immagine 2 di 2
    • Using the plastic opening tool, carefully open and remove the case. Slide the tool along the edge and pry upwards to open.
  16. LG Xenon Front Case/Screen Replacement: passo 16, immagine 1 di 1
    • Remove the black electrical tape holding the LCD to the screen.
  17. LG Xenon Front Case/Screen Replacement: passo 17, immagine 1 di 1
    • Un-clasp the small tab in the top right corner.
  18. LG Xenon Front Case/Screen Replacement: passo 18, immagine 1 di 3 LG Xenon Front Case/Screen Replacement: passo 18, immagine 2 di 3 LG Xenon Front Case/Screen Replacement: passo 18, immagine 3 di 3
    • Unhook the LCD from tabs on the bottom using the plastic opening tool.
    • Remove the LCD. Be careful, the LCD screen is fragile.
  19. LG Xenon Front Case/Screen Replacement, Front Case/Screen: passo 19, immagine 1 di 2 LG Xenon Front Case/Screen Replacement, Front Case/Screen: passo 19, immagine 2 di 2
    • Once you have removed the LCD, the front case/screen will be left.
    • If necessary, you may remove the call/mute/hang up button.
Conclusione
Cal Poly, Team 9-41, Regan Spring 2012 Membro di Cal Poly, Team 9-41, Regan Spring 2012
CPSU-REGAN-S12S9G41
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,110
