Salta al contenuto principale
LG Xenon Battery Replacement
  1. LG Xenon Battery Replacement, Back Case: passo 1, immagine 1 di 1
    • Turn the phone over so the back side is facing you.
  2. LG Xenon Battery Replacement: passo 2, immagine 1 di 2 LG Xenon Battery Replacement: passo 2, immagine 2 di 2
    • Placing your thumb on the bottom of the phone, apply pressure to the small ridge in the middle of the phone and push upward towards the camera.
    • The back casing should slide off.
  3. LG Xenon Battery Replacement, Battery: passo 3, immagine 1 di 2 LG Xenon Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
    • The battery should easily fall out after the top of the battery has been pulled out.
Conclusione
Cal Poly, Team 9-41, Regan Spring 2012 Membro di Cal Poly, Team 9-41, Regan Spring 2012
CPSU-REGAN-S12S9G41
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,295
