Introduzione
This guide will show you how to disassemble the LG Vu CU920 and remove its motherboard. You will need to handle several 3.5mm screws and remove small components from the motherboard.
Cosa ti serve
Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
Remove the two 3.5 mm screws above the battery port with a Phillips #00 screwdriver.
