Parti
Nessuna parte richiesta.
Use a plastic opening tool to pry up and remove the screw covers located in the corners by the speakers
  • Use a plastic opening tool to pry up and remove the screw covers located in the corners by the speakers
Aggiungi Commento
Unscrew the four screws under the covers with a #00 screw driver. Unscrew the four screws under the covers with a #00 screw driver.
  • Unscrew the four screws under the covers with a #00 screw driver.
Aggiungi Commento
Carefully pry open the front of the phone. When opening the phone be careful of the ribbon holding the top to the rest of the phone.
  • Carefully pry open the front of the phone.
    • When opening the phone be careful of the ribbon holding the top to the rest of the phone.
Aggiungi Commento
Carefully pry off the screen. Carefully pry off the screen.
  • Carefully pry off the screen.
Aggiungi Commento
Conclusione
Michelle
Membro da: 10/04/2012
17 Reputazione
3 Guide realizzate
Cal Poly, Team 17-26, Amido Spring 2012 Membro di Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 574
