Parti
Nessuna parte richiesta.
Turn the phone onto its side so the label micro SD is facing upside down.
  • Turn the phone onto its side so the label micro SD is facing upside down.
  • Once on its side, lift the micro SD cover up and swivel it away from the opening.
Aggiungi Commento
The Micro SD card will appear as a thin plastic piece sticking out of the phone Gently push down on the card, you should hear a click, and then it will "spring" back at you.
  • The Micro SD card will appear as a thin plastic piece sticking out of the phone
  • Gently push down on the card, you should hear a click, and then it will "spring" back at you.
  • The card should be sticking out of the phone slightly once this is done.
  • Remove the card from the slot
Aggiungi Commento
Conclusione
Michelle
Membro da: 10/04/2012
17 Reputazione
3 Guide realizzate
Cal Poly, Team 17-26, Amido Spring 2012 Membro di Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 300
