Parti
Nessuna parte richiesta.
Turn over the phone so the front screen is facing down and the back side is up.
  • Turn over the phone so the front screen is facing down and the back side is up.
Aggiungi Commento
Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
Aggiungi Commento
To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
  • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
  • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
  • Then press down on the bottom of the battery and it should snap into place
Aggiungi Commento
First remove the rubber stoppers covering the screws on the back of the phone by prying them up and away from the phone. First remove the rubber stoppers covering the screws on the back of the phone by prying them up and away from the phone.
  • First remove the rubber stoppers covering the screws on the back of the phone by prying them up and away from the phone.
Aggiungi Commento
Remove the 3.61mm length, Phillips screws from the back of the phone using the #00 screwdriver. Remove the 3.61mm length, Phillips screws from the back of the phone using the #00 screwdriver.
  • Remove the 3.61mm length, Phillips screws from the back of the phone using the #00 screwdriver.
Aggiungi Commento
Now pry open the back of the phone. Make sure that you use the plastic opening tool to go around the entire phone to help open the phone.
  • Now pry open the back of the phone.
  • Make sure that you use the plastic opening tool to go around the entire phone to help open the phone.
Aggiungi Commento
Carefully separate the keyboard from the top of the phone. Be careful not to break the ribbon cable.
  • Carefully separate the keyboard from the top of the phone.
  • Be careful not to break the ribbon cable.
Aggiungi Commento
Detach the keyboard from the phone by taking off the little metal latches.
  • Detach the keyboard from the phone by taking off the little metal latches.
  • When replacing the old keyboard with a new one you will have to solder the metal latches to the new board.
Aggiungi Commento
Conclusione
Cal Poly, Team 17-26, Amido Spring 2012 Membro di Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 317
