Introduzione
If your speakers decide to break you can use this repair guide to replace them. If you are planing to do this it requires soldering of small parts, so only follow this guide if you feel comfortable doing this.
Remove the two triangular pads at the top of the two speakers.
  • Remove the two triangular pads at the top of the two speakers.
  • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
Aggiungi Commento
Remove the two rubber cylinders from their shafts. These cover more screws.
  • Remove the two rubber cylinders from their shafts. These cover more screws.
  • This requires a little more effort, so you may need to "dig" them out.
Aggiungi Commento
Now remove the four screws.
  • Now remove the four screws.
  • The screws are small, so put them somewhere that you can easily keep track of them.
Aggiungi Commento
Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
  • Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
  • You should hear popping or snapping noises as the faceplate is being removed.
Aggiungi Commento
The faceplate is attached by wires, so do not pull the faceplate very far away from the phone. The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
  • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
The faceplate is still attached through speakers that travel from the ear-piece to the motherboard. Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate. This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
  • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
  • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
Aggiungi Commento
The faceplate and keypad can now be completely removed from the phone.
  • The faceplate and keypad can now be completely removed from the phone.
Aggiungi Commento
Wedge the spudger into the small gap between the phone and the metal casing of the motherboard. Slide the spudger underneath the metal and along the edge. The motherboard should begin to rise. There is a ribbon at the end of this groove, do not slide the spudger into the ribbon.
  • Wedge the spudger into the small gap between the phone and the metal casing of the motherboard.
  • Slide the spudger underneath the metal and along the edge. The motherboard should begin to rise.
    • There is a ribbon at the end of this groove, do not slide the spudger into the ribbon.
  • Now use the spudger to lift the other side of the motherboard.
Aggiungi Commento
Lift the motherboard at an angle.
  • Lift the motherboard at an angle.
    • Do not completely remove the motherboard. Doing so will tear the ribbon!
Aggiungi Commento
Gently pull the LCD screen upwards. It can be tricky do this, you may want to use a spudger to pry it up if it doesn't pull up easily.
  • Gently pull the LCD screen upwards.
    • It can be tricky do this, you may want to use a spudger to pry it up if it doesn't pull up easily.
  • This step requires soldering. Only do this step if you are OK with soldering small wires.
Aggiungi Commento
Carefully move the LCD screen in front of the logic board and use the spudger to pry against the edge of the speaker The speaker should just pop right out. The only thing holding it in place is an adhesive
  • Carefully move the LCD screen in front of the logic board and use the spudger to pry against the edge of the speaker
  • The speaker should just pop right out. The only thing holding it in place is an adhesive
Aggiungi Commento
Remove speaker wires from the LCD screen
  • Remove speaker wires from the LCD screen
  • Replace the speaker and solder back the connections to the LCD screen.
  • This step requires soldering. So only remove wires if you are comfortable soldering together small wires.
Aggiungi Commento
Use the spudger to pry against the left speaker to remove it. Two wires attach the speaker to the logic board, so handle carefully.
  • Use the spudger to pry against the left speaker to remove it.
  • Two wires attach the speaker to the logic board, so handle carefully.
Aggiungi Commento
remove the wires connected to the logic board
  • remove the wires connected to the logic board
  • Replace the speaker and solder the connections back to the logic board
  • Only remove wires if you are comfortable soldering on a small scale.
Aggiungi Commento
Linea Traguardo
Steven Clark
Membro da: 21/01/2010
29 Reputazione
2 Guide realizzate
Cal Poly, Team 16-32, Maness Winter 2010 Membro di Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,000
