Salta al contenuto principale
LG VX8560 Side Key Replacement
Cosa ti serve
  1. LG VX8560 Side Key Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the phone over so its backside is facing up
  2. LG VX8560 Side Key Replacement: passo 2, immagine 1 di 1
    • Push the battery cover from the indentation and slide the battery cover away from phone to remove battery cover
  3. LG VX8560 Side Key Replacement: passo 3, immagine 1 di 2 LG VX8560 Side Key Replacement: passo 3, immagine 2 di 2
    • Remove the battery from the phone
  4. LG VX8560 Side Key Replacement, Side Keys: passo 4, immagine 1 di 2 LG VX8560 Side Key Replacement, Side Keys: passo 4, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove all four screws that are visible along the edge of the phone
  5. LG VX8560 Side Key Replacement: passo 5, immagine 1 di 3 LG VX8560 Side Key Replacement: passo 5, immagine 2 di 3 LG VX8560 Side Key Replacement: passo 5, immagine 3 di 3
    • Find the seam between the phone’s keypad cover and back cover, and slide a plastic pry tool along the edge to gently pry the two pieces apart without completely separating them.
    • The motherboard should be visible. Do not separate the two covers. They should be held together by a screw at the axis of the phone.
  6. LG VX8560 Side Key Replacement: passo 6, immagine 1 di 2 LG VX8560 Side Key Replacement: passo 6, immagine 2 di 2
    • Place the side keys so that they are aligned with the silver circles located on the side of the motherboard.
Conclusione
Kevin
Membro da: 04/18/13
7 Reputazione
2 Guide realizzate
Cal Poly, Team 13-62, Johann Spring 2013 Membro di Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 232
