Introduzione
Replace damaged keypad.
Parti
Nessuna parte richiesta.
Lay the phone face down with the screen in palm of hand.
  • Lay the phone face down with the screen in palm of hand.
  • Slide the grey button towards the top of the phone.
Aggiungi Commento
While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
  • While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
  • Pull the battery up vertically to completely remove from phone.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Locate four screws underneath of the battery.
  • Locate four screws underneath of the battery.
  • Remove screws by turning counter clockwise with screwdriver until they pop out.
Aggiungi Commento
Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
  • Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
  • Note: There will be a significant amount of resistance.
Aggiungi Commento
Lift up logic board without completely removing from phone.
  • Lift up logic board without completely removing from phone.
  • Remove entire keypad from beneath the logic board.
Aggiungi Commento
Insert replacement keypad with buttons aligned in proper holes.
  • Insert replacement keypad with buttons aligned in proper holes.
Aggiungi Commento
Conclusione
Nichole Shaw
Membro da: 13/04/2010
1 Reputazione
14 Guide realizzate
Cal Poly, Team 18-75, Johann Spring 2010 Membro di Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 996
