Remove the four grey plugs using either tweezers or a push pin.
  • Remove the four grey plugs using either tweezers or a push pin.
Aggiungi Commento
Remove the four screws that are now exposed using a Phillips #00 screwdriver.
  • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
  • Be sure to put the screws in a safe place as they are very small and easy to lose.
Aggiungi Commento
Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
  • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
  • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
  • Do this across the entire length of the seem until the case is no longer attached to the phone.
Aggiungi Commento
The case can now be removed and the interior of the front is accessible.
  • The case can now be removed and the interior of the front is accessible.
Aggiungi Commento
Locate the four solder joints (connected to the yellow, black, blue, and red wires) on the bottom part of the phone, connected to the speaker. It will appear as a black circular part with some holes in it. Place a piece of solder wick on top of the solders.
  • Locate the four solder joints (connected to the yellow, black, blue, and red wires) on the bottom part of the phone, connected to the speaker. It will appear as a black circular part with some holes in it.
  • Place a piece of solder wick on top of the solders.
  • Very carefully, place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
  • Soldering iron will damage circuitry if held down for too long.
  • Cut off the used solder wick with pliers and repeat this step if any solder remains.
Aggiungi Commento
After the solder has been removed, pry out the speaker with the plastic opening tool.
  • After the solder has been removed, pry out the speaker with the plastic opening tool.
Aggiungi Commento
Conclusione
Ryan Bishop
Membro da: 17/04/2012
1 Reputazione
6 Guide realizzate
Cal Poly, Team 12-39, Regan Spring 2012 Membro di Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 437
