Introduzione
This guide will go step-by-step through the process of accessing the phone's main display. Pictures and instructions accompany each step in the guide.
Push down on the gray "PUSH" button on the back side of the phone.
  • Push down on the gray "PUSH" button on the back side of the phone.
  • Slide back case downward. Then, lift and remove case.
Aggiungi Commento
Align gold prongs with gold plates on the bottom of the battery. Make sure the "This side up" is showing.
  • Align gold prongs with gold plates on the bottom of the battery. Make sure the "This side up" is showing.
  • Push battery flat against the back of the phone until it clicks into place.
Aggiungi Commento
Remove the four grey plugs using either tweezers or a push pin.
  • Remove the four grey plugs using either tweezers or a push pin.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Remove the four screws that are now exposed using a Phillips #00 screwdriver.
  • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
  • Be sure to put the screws in a safe place as they are very small and easy to lose.
Aggiungi Commento
Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
  • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
  • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
  • Do this across the entire length of the seem until the case is no longer attached to the phone.
Aggiungi Commento
The case can now be removed and the interior of the front is accessible.
  • The case can now be removed and the interior of the front is accessible.
Aggiungi Commento
Locate the solder on the side of the metal plate on the top half of the phone. Place a piece of solder wick on top of the solder.
  • Locate the solder on the side of the metal plate on the top half of the phone.
  • Place a piece of solder wick on top of the solder.
  • To desolder the connection, very carefully place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
  • The soldering iron will damage circuitry if held down for too long.
  • Cut off the used solder wick with pliers and repeat this step if any solder remains.
Aggiungi Commento
After the solder has been removed, pry off the camera assembly connection shield with the plastic opening tool.
  • After the solder has been removed, pry off the camera assembly connection shield with the plastic opening tool.
Aggiungi Commento
Remove the main display by lifting up the extruded white edge with your fingernail. Remove the main display by lifting up the extruded white edge with your fingernail.
  • Remove the main display by lifting up the extruded white edge with your fingernail.
Aggiungi Commento
Conclusione
Ryan Bishop
Membro da: 17/04/2012
1 Reputazione
6 Guide realizzate
Cal Poly, Team 12-39, Regan Spring 2012 Membro di Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 901
