Salta al contenuto principale
LG VX6100 Front Case Replacement
Cosa ti serve
  1. LG VX6100 Front Case Replacement, Front Case: passo 1, immagine 1 di 1
    • Remove the four grey plugs using either tweezers or a push pin.
  2. LG VX6100 Front Case Replacement: passo 2, immagine 1 di 1
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
  3. LG VX6100 Front Case Replacement: passo 3, immagine 1 di 1
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
  4. LG VX6100 Front Case Replacement: passo 4, immagine 1 di 1
    • The case can now be removed and the interior of the front is accessible.
Conclusione
Ryan Bishop
Membro da: 04/17/12
1 Reputazione
3 Guide realizzate
Cal Poly, Team 12-39, Regan Spring 2012 Membro di Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 765
