Salta al contenuto principale
LG VX6100 Battery Replacement
Cosa ti serve
  1. LG VX6100 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Open the battery casing by pressing the gray "PUSH" button. Slide the back of the casing downward.
    • Carefully remove the faulty battery from the back of the phone.
    • Inspect the battery port to ensure the battery is the issue. Ensure the four gold connecting prongs are intact and are pointing straight into the port.
  2. LG VX6100 Battery Replacement: passo 3, immagine 1 di 1
    • Align the gold prongs with the gold plates on the bottom of the battery. Make sure "This Side Up" is visible
    • Push the battery flat against the back of the phone until it clicks into place.
    • Replace the back cover of the phone by sliding the casing down into place. Gently press the top until it clicks.
    • Charge the device and turn it on to confirm the issue is resolved.
Conclusione
If after completing the replacement, the device still does not operate properly, further troubleshooting must be done to find and solve the issue.
Eric Funsten
Membro da: 04/17/12
1 Reputazione
3 Guide realizzate
Cal Poly, Team 12-39, Regan Spring 2012 Membro di Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 796
