Introduzione
Most of the bottom portion of the phone will need to be removed to install a new motherboard.
Cosa ti serve
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Grasp the edges of the phone with one hand.
Unscrew the six 5.0-mm Phillips #000 screws located around each side of the back panel of the phone.
