Salta al contenuto principale
LG VX5500 Phone Casing Replacement
Cosa ti serve
  1. LG VX5500 Phone Casing Replacement, Battery: passo 1, immagine 1 di 3 LG VX5500 Phone Casing Replacement, Battery: passo 1, immagine 2 di 3 LG VX5500 Phone Casing Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Phone Casing Replacement, Mother Board: passo 2, immagine 1 di 2 LG VX5500 Phone Casing Replacement, Mother Board: passo 2, immagine 2 di 2
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
  3. LG VX5500 Phone Casing Replacement: passo 3, immagine 1 di 3 LG VX5500 Phone Casing Replacement: passo 3, immagine 2 di 3 LG VX5500 Phone Casing Replacement: passo 3, immagine 3 di 3
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
  4. LG VX5500 Phone Casing Replacement: passo 4, immagine 1 di 2 LG VX5500 Phone Casing Replacement: passo 4, immagine 2 di 2
    • Peel back the sticker with tweezers and hold it back with your finger.
    • Use the tweezers to lift the display adapter off the logic board.
  5. LG VX5500 Phone Casing Replacement: passo 5, immagine 1 di 2 LG VX5500 Phone Casing Replacement: passo 5, immagine 2 di 2
    • Lift the mother board out of the phone casing.
    • The keyboard can be easily removed once the mother board is out of the phone.
  6. LG VX5500 Phone Casing Replacement, Phone Casing: passo 6, immagine 1 di 2 LG VX5500 Phone Casing Replacement, Phone Casing: passo 6, immagine 2 di 2
    • Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
    • The screen cover is adhered to the phone and may take some effort to pry off. If it is too difficult to remove, heat the screen with a hair dryer on low for 30 seconds to soften the adhesive.
  7. LG VX5500 Phone Casing Replacement: passo 7, immagine 1 di 2 LG VX5500 Phone Casing Replacement: passo 7, immagine 2 di 2
    • Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
    • The bottom two screws may have small rubber covers that you can remove using tweezers.
  8. LG VX5500 Phone Casing Replacement: passo 8, immagine 1 di 3 LG VX5500 Phone Casing Replacement: passo 8, immagine 2 di 3 LG VX5500 Phone Casing Replacement: passo 8, immagine 3 di 3
    • Pry off the front panel of the phone using a Plastic Opening Tool.
    • Push the tool into the crack along the side of the phone.
    • Slide the tool along the crack to detach the tabs holding the backing on the phone.
  9. LG VX5500 Phone Casing Replacement: passo 9, immagine 1 di 2 LG VX5500 Phone Casing Replacement: passo 9, immagine 2 di 2
    • Use the tweezers to lift the display adapter off the screen component.
  10. LG VX5500 Phone Casing Replacement: passo 10, immagine 1 di 2 LG VX5500 Phone Casing Replacement: passo 10, immagine 2 di 2
    • Using tweezers remove the speaker from its casing.
    • The speaker is adhered to the phone casing so it will take a small amount of force to remove it.
  11. LG VX5500 Phone Casing Replacement: passo 11, immagine 1 di 2 LG VX5500 Phone Casing Replacement: passo 11, immagine 2 di 2
    • Remove the earpiece and gyroscope by lifting them out of the phone casing using tweezers.
    • The earpiece and gyroscope are adhered to the phone casing so it will take a small amount of force to remove them.
    • Be careful when removing these components as the connecting wires are easily broken/disconnected.
  12. LG VX5500 Phone Casing Replacement: passo 12, immagine 1 di 1
    • Lift the screen components out of the phone.
  13. LG VX5500 Phone Casing Replacement: passo 13, immagine 1 di 1
    • The phone is now fully disassembled.
    • Replace the parts indicated with your new phone casing.
Conclusione
Altre 3 persone hanno completato questa guida.
Henry
Membro da: 04/12/12
181 Reputazione
3 Guide realizzate
Cal Poly, Team 7-33, Maness Spring 2012 Membro di Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 564
