Introduzione
This guide gives step-by-step instructions on how to remove the mother board in the LG VX5500 cell phone. To complete the task you will need a #00 Phillip's head screwdriver, tweezers, and a plastic opening tool.
Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery. Our device did not come with a battery cover so it is not shown here. Remove the battery using your finger to pry it out of the battery housing.
  • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
  • Our device did not come with a battery cover so it is not shown here.
  • Remove the battery using your finger to pry it out of the battery housing.
Aggiungi Commento
Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack. Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
  • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
  • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Carefully pry off the phone's backing using a plastic opening tool. Slip the tool into the crack between the keypad (front panel) and the back panel. Slide the tool along the sides of the phone to detach the tabs holding the backing on.
  • Carefully pry off the phone's backing using a plastic opening tool.
  • Slip the tool into the crack between the keypad (front panel) and the back panel.
  • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
Aggiungi Commento
Peel back the sticker with tweezers and hold it back with your finger. Use the tweezers to lift the display adapter off the logic board.
  • Peel back the sticker with tweezers and hold it back with your finger.
  • Use the tweezers to lift the display adapter off the logic board.
Aggiungi Commento
Lift the mother board out of the phone casing. The keyboard can be easily removed once the mother board is out of the phone.
  • Lift the mother board out of the phone casing.
  • The keyboard can be easily removed once the mother board is out of the phone.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Henry
Membro da: 12/04/2012
181 Reputazione
5 Guide realizzate
Cal Poly, Team 7-33, Maness Spring 2012 Membro di Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Membri
9 Guide realizzate
You guys are great!
Kurt Beske - Replica
So what do you do with the mother board then?
Erik Sodders - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,526
