Introduzione
Often times the key pad could break or become worn. This repair guide will show you how to replace the the keypad of the LG VX5400.
Parti
Nessuna parte richiesta.
Turn off the cell phone and turn it over on its back side
  • Turn off the cell phone and turn it over on its back side
Aggiungi Commento
Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
Aggiungi Commento
Slide a tool or finger into the notch at the top of the battery  to carefully remove it. Slide a tool or finger into the notch at the top of the battery  to carefully remove it. Slide a tool or finger into the notch at the top of the battery  to carefully remove it.
  • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
Aggiungi Commento
Remove the rubber stopper from the back top of the phone with the pointed end of a spudger.
  • Remove the rubber stopper from the back top of the phone with the pointed end of a spudger.
Aggiungi Commento
Use the Phillip screw driver to remove the hidden screw, which is marked by the red square
  • Use the Phillip screw driver to remove the hidden screw, which is marked by the red square
Aggiungi Commento
Gently split open the front and back of the bottom casing of the phone with fingers.
  • Gently split open the front and back of the bottom casing of the phone with fingers.
Aggiungi Commento
Carefully pull the key pad from the phone through the opening.
  • Carefully pull the key pad from the phone through the opening.
Aggiungi Commento
See here for parts that have been removed.
  • See here for parts that have been removed.
Aggiungi Commento
Conclusione
Cal Poly, Team 26-26, Regan Spring 2010 Membro di Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,209
