Salta al contenuto principale
LG VX5200 Screen Replacement
Cosa ti serve
  1. LG VX5200 Screen Replacement, Screen: passo 1, immagine 1 di 3 LG VX5200 Screen Replacement, Screen: passo 1, immagine 2 di 3 LG VX5200 Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Pry the grey pieces of plastic off the corners of the screen with a spudger.
  2. LG VX5200 Screen Replacement: passo 2, immagine 1 di 2 LG VX5200 Screen Replacement: passo 2, immagine 2 di 2
    • Unscrew each of the four screws with a Phillips #00 Screwdriver.
    • These screws are the same size as the ones from the back casing, but are not the same size as the screw from the antenna.
  3. LG VX5200 Screen Replacement: passo 3, immagine 1 di 2 LG VX5200 Screen Replacement: passo 3, immagine 2 di 2
    • Close the phone after removing the screws.
    • Slide a spudger into the cracks in the top half of the phone's casing.
    • Wedge and lever the spudger to remove the casing.
    • Apply constant pressure to avoid cracking the plastic casing. This step can take a few minutes.
  4. LG VX5200 Screen Replacement: passo 4, immagine 1 di 3 LG VX5200 Screen Replacement: passo 4, immagine 2 di 3 LG VX5200 Screen Replacement: passo 4, immagine 3 di 3
    • Remove the chipboard from the screen by sliding a plastic spudger under the screen and lifting.
    • Use a plastic spudger to avoid short-circuiting the phone's electronics.
    • Gently lift the speaker out of the plastic casing using a plastic spudger.
    • Remove the small battery adjacent to the speaker with a plastic spudger.
  5. LG VX5200 Screen Replacement: passo 5, immagine 1 di 3 LG VX5200 Screen Replacement: passo 5, immagine 2 di 3 LG VX5200 Screen Replacement: passo 5, immagine 3 di 3
    • Slide and lever a plastic spudger between the screen and it's housing.
    • Avoid tearing the wires connecting the screen, the small battery and the speaker.
    • Remove the chip connecting the screen to the camera using your fingers.
Conclusione
jmarcum
Membro da: 10/28/09
16 Reputazione
1 Guida realizzata
Cal Poly, Team 9-18, Regan Fall 2009 Membro di Cal Poly, Team 9-18, Regan Fall 2009
CPSU-REGAN-F09S9G18
5 Membri
2 Guide realizzate
Un commento
The “battery” beside the speaker isn’t the battery, it’s the phone vibrator. Still a good guide, however
Kaleb White - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,392
