Introduzione
This guide shows how to remove the battery of the LG VX5200 cell phone.
Turn off the cellphone. Remove the cover of the cellphone by applying downward pressure to raised area and pushing away from antenna. Remove the battery by lifting up with your finger in the space at the top of the device.
  • Turn off the cellphone.
  • Remove the cover of the cellphone by applying downward pressure to raised area and pushing away from antenna.
  • Remove the battery by lifting up with your finger in the space at the top of the device.
Aggiungi Commento
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Place the battery to the side  away from liquids or heat.
  • Place the battery to the side away from liquids or heat.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
jmarcum
Membro da: 28/10/2009
16 Reputazione
4 Guide realizzate
Cal Poly, Team 9-18, Regan Fall 2009 Membro di Cal Poly, Team 9-18, Regan Fall 2009
CPSU-REGAN-F09S9G18
5 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,637
