Introduzione
A guide to replace the antenna.
Parti
Nessuna parte richiesta.
Turn the phone on its back. Turn the phone on its back.
  • Turn the phone on its back.
Aggiungi Commento
Orient the phone as shown. Remove the battery cover by pushing upward with your thumb.
  • Orient the phone as shown.
  • Remove the battery cover by pushing upward with your thumb.
Aggiungi Commento
Place your fingernail at the top of the battery and pry the battery out towards you. Place your fingernail at the top of the battery and pry the battery out towards you.
  • Place your fingernail at the top of the battery and pry the battery out towards you.
Aggiungi Commento
Orient the phone as shown with the battery already removed.
  • Orient the phone as shown with the battery already removed.
Aggiungi Commento
Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards. Use a Phillips #00 screwdriver to remove the 5 screws as shown here. Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
  • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
Aggiungi Commento
Place an iPod opener tool in the seam above the antenna. Run the tool around the perimeter of the entire phone. Run the tool around the perimeter of the entire phone.
  • Place an iPod opener tool in the seam above the antenna.
  • Run the tool around the perimeter of the entire phone.
Aggiungi Commento
Check to see that your device looks like the attached photo.
  • Check to see that your device looks like the attached photo.
Aggiungi Commento
Locate the screw and copper fixture that hold the antenna in place.
  • Locate the screw and copper fixture that hold the antenna in place.
  • Remove the screw from the device using a Philips #00 screwdriver.
Aggiungi Commento
Remove the copper fixture after it has been unscrewed. Remove the copper fixture after it has been unscrewed.
  • Remove the copper fixture after it has been unscrewed.
Aggiungi Commento
Check to see that your device looks like the attached photo. Check to see that your device looks like the attached photo.
Aggiungi Commento
Conclusione
Douglas Blaalid
Membro da: 13/01/2010
282 Reputazione
15 Guide realizzate
Cal Poly, Team 4-13, Forte Winter 2010 Membro di Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Membri
15 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,297
