Introduzione
Repairing the logic board.
Turn the closed phone so that the back panel is facing you.
  • Turn the closed phone so that the back panel is facing you.
  • Press down and forward firmly on the gray tab in the middle of the phone.
Aggiungi Commento
Now just lift up on the battery and remove it from the phone. Now just lift up on the battery and remove it from the phone.
  • Now just lift up on the battery and remove it from the phone.
Aggiungi Commento
Remove the rubber grommet using a Spudger.
  • Remove the rubber grommet using a Spudger.
Aggiungi Commento
Be sure not to lose the screws. They are small!
  • Be sure not to lose the screws. They are small!
  • Remove the five screws using a Phillips #00 Screwdriver.
Aggiungi Commento
When removing back cover, be careful not to break the speaker wires. Using an iPod Opening Tool, carefully pry off the back cover. Using Tweezers, gently pull speaker wires out.
  • When removing back cover, be careful not to break the speaker wires.
  • Using an iPod Opening Tool, carefully pry off the back cover.
  • Using Tweezers, gently pull speaker wires out.
Aggiungi Commento
Separate the two halves.
  • Separate the two halves.
Aggiungi Commento
Carefully pry and lift up on the logic board using an iPod Opening Tool. Carefully pry and lift up on the logic board using an iPod Opening Tool. Carefully pry and lift up on the logic board using an iPod Opening Tool.
  • Carefully pry and lift up on the logic board using an iPod Opening Tool.
Aggiungi Commento
Carefully flip the logic board up and out of the way.
  • Carefully flip the logic board up and out of the way.
Aggiungi Commento
Use an iPod Opening Tool to lift up on the keypad and pull it out. Use an iPod Opening Tool to lift up on the keypad and pull it out. Use an iPod Opening Tool to lift up on the keypad and pull it out.
  • Use an iPod Opening Tool to lift up on the keypad and pull it out.
Aggiungi Commento
DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
  • DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
  • De-solder solder joint on front using Soldering Iron.
Aggiungi Commento
De-solder solder joint on the back using Soldering Iron.
  • De-solder solder joint on the back using Soldering Iron.
Aggiungi Commento
Carefully detach ribbon cable and remove logic board. Carefully detach ribbon cable and remove logic board. Carefully detach ribbon cable and remove logic board.
  • Carefully detach ribbon cable and remove logic board.
Aggiungi Commento
Conclusione
David Foster
Membro da: 11/04/2010
1 Reputazione
16 Guide realizzate
Cal Poly, Team 25-88, Amido Spring 2010 Membro di Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,454
