Introduzione
- If your LG VX4500 screen does not operate properly due to being cracked, shattered, or dead, you may want to replace it.
- A properly functioning LCD display screen will clearly reveal text and photos without interruption.
- Steps 6 and 7 require the use of a spudger to remove the speaker and vibrator.
- Step 9 will require you to desolder the solder joint using a soldering iron.
- This guide is straightforward and will help you replace the display screen in less than an hour.
- Make sure the cell phone is turned off and unplugged before you begin.
Cosa ti serve
Turn the closed phone so that the back panel is facing you.
Press down and forward firmly on the gray tab in the middle of the phone.
Quasi finito!
Conclusione
