Introduzione
This guide will show you how to replace the screen.
Parti
Nessuna parte richiesta.
Remove the four rubber stoppers around the main screen using a pointed-end spudger Remove the four rubber stoppers around the main screen using a pointed-end spudger
  • Remove the four rubber stoppers around the main screen using a pointed-end spudger
Aggiungi Commento
Use a number #00 Philips screwdriver to unscrew the four screws under the rubber stoppers
  • Use a number #00 Philips screwdriver to unscrew the four screws under the rubber stoppers
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Use a plastic opening tool, pry the top end open Whilst prying the top panel with one plastic opening tool, use a thinner iPod opening tool to slide down the gap and pry open the case Free the opposite side in the same manner
  • Use a plastic opening tool, pry the top end open
  • Whilst prying the top panel with one plastic opening tool, use a thinner iPod opening tool to slide down the gap and pry open the case
  • Free the opposite side in the same manner
Aggiungi Commento
Remove plastic screen panel to reveal internal components Remove plastic screen panel to reveal internal components
  • Remove plastic screen panel to reveal internal components
Aggiungi Commento
Remove the screen board by lifting away from the phone Remove speaker by prying with a spudger Remove speaker by prying with a spudger
  • Remove the screen board by lifting away from the phone
  • Remove speaker by prying with a spudger
Aggiungi Commento
Once screen board is pulled away, gently press out the plastic screen Once screen board is pulled away, gently press out the plastic screen Once screen board is pulled away, gently press out the plastic screen
  • Once screen board is pulled away, gently press out the plastic screen
Aggiungi Commento
Conclusione
Nico Chiarito
Membro da: 21/01/2010
22 Reputazione
8 Guide realizzate
Cal Poly, Team 8-47, Regan Winter 2010 Membro di Cal Poly, Team 8-47, Regan Winter 2010
CPSU-REGAN-W10S8G47
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,308
