Push the light gray rectangle in the top-center up. While pushing up grab the sides of the battery and pull out. While pushing up grab the sides of the battery and pull out.
  • Push the light gray rectangle in the top-center up.
  • While pushing up grab the sides of the battery and pull out.
Aggiungi Commento
Unscrew the antenna by grasping the base and twisting counterclockwise.
  • Unscrew the antenna by grasping the base and twisting counterclockwise.
    • The antenna may separate from a black sleeve during removal. You may need to use tweezers to remove the sleeve. Remove both the antenna and the sleeve and set aside.
Aggiungi Commento
The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside. The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside. The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
  • The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
Aggiungi Commento
Using a Torx screwdriver with a T6-sized bit, unscrew the four screws on the back of the phone. The bit size is engraved on the base of the bit head.
  • Using a Torx screwdriver with a T6-sized bit, unscrew the four screws on the back of the phone.
    • The bit size is engraved on the base of the bit head.
Aggiungi Commento
With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone. Gently pull the two pieces apart to separate. Apply enough force to separate the pieces without cracking the back cover.
  • With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone.
  • Gently pull the two pieces apart to separate.
    • Apply enough force to separate the pieces without cracking the back cover.
Aggiungi Commento
Lift the computer chip to gain access to the keypad and side buttons beneath. CAUTION: The computer chip is attached with a thin ribbon wire at upper right corner of case. DO NOT BREAK THE RIBBON WIRE.
  • Lift the computer chip to gain access to the keypad and side buttons beneath.
    • CAUTION: The computer chip is attached with a thin ribbon wire at upper right corner of case. DO NOT BREAK THE RIBBON WIRE.
Aggiungi Commento
Conclusione
<b>To reassemble your device, follow these instructions in reverse order.</b>
Nico Chiarito
Membro da: 21/01/2010
22 Reputazione
8 Guide realizzate
Cal Poly, Team 8-47, Regan Winter 2010 Membro di Cal Poly, Team 8-47, Regan Winter 2010
CPSU-REGAN-W10S8G47
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,437
