Introduzione
Make sure your phone is turned off.
Parti
Nessuna parte richiesta.
Remove the back cover of the phone using your fingernail or a plastic opening tool. There is a notch located at the bottom of the phone that can be used for opening leverage.
  • Remove the back cover of the phone using your fingernail or a plastic opening tool.
  • There is a notch located at the bottom of the phone that can be used for opening leverage.
Aggiungi Commento
The battery is located at the bottom half of the phone with the LG logo on it. There is a semi-circular notch at the bottom edge of the battery with the silver screw in it.
  • The battery is located at the bottom half of the phone with the LG logo on it.
  • There is a semi-circular notch at the bottom edge of the battery with the silver screw in it.
  • Place a finger in the notch and push up against the battery to pop it out.
Aggiungi Commento
Remove three screws from the bottom of the phone. These three screws are located on the speaker itself.
  • Remove three screws from the bottom of the phone. These three screws are located on the speaker itself.
  • 2 - 5.5mm length PH00 screws
  • 1 - 4mm length PH00 screws
Aggiungi Commento
There is a notch located at the bottom of the speaker. Insert a fingernail in to the notch and pull up. There is a notch located at the bottom of the speaker. Insert a fingernail in to the notch and pull up.
  • There is a notch located at the bottom of the speaker. Insert a fingernail in to the notch and pull up.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Kenny Richmond
Membro da: 20/01/2015
260 Reputazione
2 Guide realizzate
USF Tampa, Team 1-6, Blackwell Winter 2015 Membro di USF Tampa, Team 1-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G6
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 128
