Salta al contenuto principale
LG Thrill 4G SIM/Micro SD Card Replacement
Cosa ti serve
  1. LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: passo 1, immagine 1 di 2 LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: passo 1, immagine 2 di 2
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
  2. LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: passo 2, immagine 1 di 2 LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: passo 2, immagine 2 di 2
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
  3. LG Thrill 4G SIM/Micro SD Card Replacement, Screw Removal: passo 3, immagine 1 di 1
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
  4. LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: passo 4, immagine 1 di 2 LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: passo 4, immagine 2 di 2
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
  5. LG Thrill 4G SIM/Micro SD Card Replacement, Buttons: passo 5, immagine 1 di 1
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
  6. LG Thrill 4G SIM/Micro SD Card Replacement: passo 6, immagine 1 di 3 LG Thrill 4G SIM/Micro SD Card Replacement: passo 6, immagine 2 di 3 LG Thrill 4G SIM/Micro SD Card Replacement: passo 6, immagine 3 di 3
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
  7. LG Thrill 4G SIM/Micro SD Card Replacement: passo 7, immagine 1 di 1
    • Remove the six Phillips #00 screws within the mid-cover bezel.
  8. LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: passo 8, immagine 1 di 3 LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: passo 8, immagine 2 di 3 LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: passo 8, immagine 3 di 3
    • Utilize a spudger or plastic opening tool and gently disconnect the ribbon cable that is attached to the black micro-SIM card board.
  9. LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: passo 9, immagine 1 di 3 LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: passo 9, immagine 2 di 3 LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: passo 9, immagine 3 di 3
    • Carefully pry the board up to detach it from its place in the phone.
    • Make sure to pry off the small tab connected to the camera unit as well.
Conclusione
Khbero Baker
Membro da: 01/19/15
128 Reputazione
1 Guida realizzata
USF Tampa, Team 1-6, Blackwell Winter 2015 Membro di USF Tampa, Team 1-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 583
