Introduzione
In this guide, you will learn to replace a cell phone battery
This guide will replace the battery for an LG Optimus V. This guide will replace the battery for an LG Optimus V.
  • This guide will replace the battery for an LG Optimus V.
Aggiungi Commento
Turn the LG Optimus V over so that the back cover is facing upward.
  • Turn the LG Optimus V over so that the back cover is facing upward.
Aggiungi Commento
Locate the opening right above the camera.
  • Locate the opening right above the camera.
  • Use your plastic spudger to detach the back cover.
Aggiungi Commento
The battery is indicated by the rectangular marker in the photo. Gently remove the battery with your spudger. The battery is indicated by the rectangular marker in the photo. Gently remove the battery with your spudger. The battery is indicated by the rectangular marker in the photo. Gently remove the battery with your spudger.
  • The battery is indicated by the rectangular marker in the photo. Gently remove the battery with your spudger.
Aggiungi Commento
Conclusione
UMass Dartmouth, Team 1-2, Shastany Fall 2013 Membro di UMass Dartmouth, Team 1-2, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G2
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 587
