Introduzione
The following guide explains how to replace the display.
Parti
Nessuna parte richiesta.
Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone. Remove the battery and simcard.
  • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
  • Remove the battery and simcard.
Aggiungi Commento
Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
  • Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
Aggiungi Commento
Remove bottom plate where the charger port is located.
  • Remove bottom plate where the charger port is located.
Aggiungi Commento
Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover. Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
Aggiungi Commento
Flip over to the face of the device. Lift off glass screen (display).
  • Flip over to the face of the device.
  • Lift off glass screen (display).
Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
Craig Lashley
Membro da: 08/10/2014
298 Reputazione
1 Guida realizzata
USF Tampa, Team 9-1, Leahy Fall 2014 Membro di USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 Membri
5 Guide realizzate
Great tutorial as always on ifixit. Just be mindful of the top clip holding the glass bevel as it can be tricky and is close to circuitry.
Sooty - Replica
Im miles i great this ifixit i'm beginner
Omair Sarip -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 29
Tutti i Tempi: 4,908
