Introduzione
The following guide explains how to replace the charger port.
Remove back cover. Remove the battery and simcard.
  • Remove back cover.
  • Remove the battery and simcard.
Aggiungi Commento
Remove the 12 screws (with the phillips head 000) around frame and near sim and sd cards.
  • Remove the 12 screws (with the phillips head 000) around frame and near sim and sd cards.
Aggiungi Commento
Remove bottom plate where the charger port is located.
  • Remove bottom plate where the charger port is located.
Aggiungi Commento
Remove the back piece. Remove the back piece.
  • Remove the back piece.
Aggiungi Commento
Using soldering iron, loosen the charger port from the bottom of the device.
  • Using soldering iron, loosen the charger port from the bottom of the device.
Aggiungi Commento
Using a smudger, lift the charger port and replace as necessary.
  • Using a smudger, lift the charger port and replace as necessary.
Aggiungi Commento
Conclusione
Bruna
Membro da: 08/10/2014
519 Reputazione
4 Guide realizzate
USF Tampa, Team 9-1, Leahy Fall 2014 Membro di USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,563
