Introduzione
Make sure your device is turned off before beginning this process.
Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage. Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
  • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
Aggiungi Commento
The battery is the large black rectangle towards the bottom half of the phone. There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out. There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
  • The battery is the large black rectangle towards the bottom half of the phone.
  • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Dale Pearson
Membro da: 22/09/2014
775 Reputazione
6 Guide realizzate
USF Tampa, Team 10-6, Brown Fall 2014 Membro di USF Tampa, Team 10-6, Brown Fall 2014
USFT-BROWN-F14S10G6
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 451
