With one hand, push the rectangular button located on the back top-side of the phone.
  • With one hand, push the rectangular button located on the back top-side of the phone.
Aggiungi Commento
With your other hand, remove the rear cover.
  • With your other hand, remove the rear cover.
Aggiungi Commento
Pull out the battery by lifting if from the cut out on the bottom end of the battery.
  • Pull out the battery by lifting if from the cut out on the bottom end of the battery.
  • Once the Battery is removed, purchase a replacement battery and insert the battery back into the phone.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 235
