Cosa ti serve
Use a spudger to remove the two screw covers below display.
Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
Note: Side buttons may fall out when removing the front case. Do not misplace them.
Note: Each side button will only fit in the side that it came from.
Insert a spudger between the black and grey casings and gently spread them apart.
Work around the device gradually, opening the gap further.
