Introduzione
You will need to use this guide if your volume buttons are not working or are worn down.
Parti
Nessuna parte richiesta.
Use a plastic opening tool to remove the back cover.
  • Use a plastic opening tool to remove the back cover.
Aggiungi Commento
Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
Aggiungi Commento
Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
Aggiungi Commento
Use a plastic opening tool to remove the back trim by working around all of the edges. Use a plastic opening tool to remove the back trim by working around all of the edges.
  • Use a plastic opening tool to remove the back trim by working around all of the edges.
Aggiungi Commento
Remove the volume buttons from the side. Remove the volume buttons from the side.
  • Remove the volume buttons from the side.
Aggiungi Commento
Conclusione
USF Tampa, Team 14-1, Leahy Fall 2014 Membro di USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 109
