Salta al contenuto principale
LG Motion 4G MS770 Speaker Replacement
Cosa ti serve
  1. LG Motion 4G MS770 Speaker Replacement, Remove the phone's back cover.: passo 1, immagine 1 di 1
    • Use a plastic opening tool to remove the back cover.
  2. LG Motion 4G MS770 Speaker Replacement, Remove the battery.: passo 2, immagine 1 di 1
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. LG Motion 4G MS770 Speaker Replacement, Remove screws.: passo 3, immagine 1 di 1
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. LG Motion 4G MS770 Speaker Replacement: passo 4, immagine 1 di 2 LG Motion 4G MS770 Speaker Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  5. LG Motion 4G MS770 Speaker Replacement: passo 5, immagine 1 di 2 LG Motion 4G MS770 Speaker Replacement: passo 5, immagine 2 di 2
    • Remove the volume buttons from the side.
  6. LG Motion 4G MS770 Speaker Replacement, Speaker: passo 6, immagine 1 di 2 LG Motion 4G MS770 Speaker Replacement, Speaker: passo 6, immagine 2 di 2
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
Conclusione
USF Tampa, Team 14-1, Leahy Fall 2014 Membro di USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 240
