Introduzione
If phone will not turn on or has system errors and the troubleshooting did not help then replace the broken motherboard with a new one.
Use a plastic opening tool to remove the back cover.
  • Use a plastic opening tool to remove the back cover.
Aggiungi Commento
Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
Aggiungi Commento
Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
Aggiungi Commento
Use a plastic opening tool to remove the back trim by working around all of the edges. Use a plastic opening tool to remove the back trim by working around all of the edges.
  • Use a plastic opening tool to remove the back trim by working around all of the edges.
Aggiungi Commento
Remove the volume buttons from the side. Remove the volume buttons from the side.
  • Remove the volume buttons from the side.
Aggiungi Commento
Use a plastic opening tool to lift the speaker off by prying under the silver square as shown. Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
  • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
  • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
Aggiungi Commento
Pry slightly underneath the tab attached to the camera until it pops off.
  • Pry slightly underneath the tab attached to the camera until it pops off.
Aggiungi Commento
Use tweezers to remove the camera, you will need to use some force as it is glued on.
  • Use tweezers to remove the camera, you will need to use some force as it is glued on.
Aggiungi Commento
Pry off the circled tabs using a plastic opening tool to release the motherboard.
  • Pry off the circled tabs using a plastic opening tool to release the motherboard.
Aggiungi Commento
Lift the motherboard off of the phone. It should come right out.
  • Lift the motherboard off of the phone. It should come right out.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Zarna Patel
Membro da: 08/10/2014
290 Reputazione
2 Guide realizzate
USF Tampa, Team 14-1, Leahy Fall 2014 Membro di USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 941
