Introduzione
This guide will show you how to replace a worn out, scratched, or damaged internal keyboard on the LG LX160 cell phone. To begin this guide, complete steps 1 to 10 of the tear down guide
Place the phone on a flat surface that the back is facing you. Remove the back panel by placing your thumb on the LG logo and sliding the panel across the length of the phone until it is removed.
  • Place the phone on a flat surface that the back is facing you. Remove the back panel by placing your thumb on the LG logo and sliding the panel across the length of the phone until it is removed.
Aggiungi Commento
Once the panel is removed, you are looking directly at the battery. It is the black rectangle in the middle of the phone.  You can remove the battery by sliding a finger into the notch where the LG logo was on the panel and lifting up the battery.
  • Once the panel is removed, you are looking directly at the battery. It is the black rectangle in the middle of the phone. You can remove the battery by sliding a finger into the notch where the LG logo was on the panel and lifting up the battery.
Aggiungi Commento
Remove the battery completely from the phone.
  • Remove the battery completely from the phone.
Aggiungi Commento
Before continuing pull off all the rubber tabs to the headphones, and the power input.
  • Before continuing pull off all the rubber tabs to the headphones, and the power input.
Aggiungi Commento
Now turn the phone so that you can see the back where the battery was.  Using a screw driver, unscrew the 6 screws holding the back casing together.
  • Now turn the phone so that you can see the back where the battery was. Using a screw driver, unscrew the 6 screws holding the back casing together.
Aggiungi Commento
At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
  • At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
  • Gently pull up on the orange wire until it comes loose. It may take some force so do not be concerned with being overly gentle.
Aggiungi Commento
After pulling on the orange wire it should come loose like the image.
  • After pulling on the orange wire it should come loose like the image.
  • Be sure that the black chip on the underside of the orange wire is all the way out like in the picture before continuing to the next step.
Aggiungi Commento
Now you can remove the logic board from the casing, and set it aside.
  • Now you can remove the logic board from the casing, and set it aside.
  • If you're replacing the logic board insert the board into the phone and attach the phone via the small orange tab
Aggiungi Commento
Peel out the keypad in the back of the phone. It is the white flimsy plastic from the bottom.
  • Peel out the keypad in the back of the phone. It is the white flimsy plastic from the bottom.
Aggiungi Commento
The keyboard will be separated and may be replaced with a new keyboard.
  • The keyboard will be separated and may be replaced with a new keyboard.
Aggiungi Commento
Conclusione
Shane Smith
Membro da: 14/01/2010
1 Reputazione
4 Guide realizzate
Cal Poly, Team 11-2, Forte Winter 2010 Membro di Cal Poly, Team 11-2, Forte Winter 2010
CPSU-FORTE-W10S11G2
5 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,398
