Introduzione
Use this guide to remove the LG LX150's front cover.
Parti
Nessuna parte richiesta.
Use the spudger to pry out the indicated rubber squares. Use the #0 Phillips screwdriver to take out the revealed screws. Use the #0 Phillips screwdriver to take out the revealed screws.
  • Use the spudger to pry out the indicated rubber squares.
  • Use the #0 Phillips screwdriver to take out the revealed screws.
Aggiungi Commento
Carefully lodge the spudger between the face plate and the hinge mechanism. Gently pry the face plate until it releases from place holders. Gently pry the face plate until it releases from place holders.
  • Carefully lodge the spudger between the face plate and the hinge mechanism.
  • Gently pry the face plate until it releases from place holders.
Aggiungi Commento
Conclusione
Tye Barba
Membro da: 15/04/2010
88 Reputazione
4 Guide realizzate
Cal Poly, Team 10-44, Garner Spring 2010 Membro di Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,778
