Introduzione
This guide will help you replace this phone's SIM card.
Remove the battery from the back of the phone by lifting up the tab.
  • Remove the battery from the back of the phone by lifting up the tab.
Aggiungi Commento
Push the SIM Card up using your thumb until it is removed. Push the SIM Card up using your thumb until it is removed.
  • Push the SIM Card up using your thumb until it is removed.
Aggiungi Commento
Once removed, replace with new SIM Card, making sure that the cut corner fits into the cut corner of the slot.
  • Once removed, replace with new SIM Card, making sure that the cut corner fits into the cut corner of the slot.
Aggiungi Commento
Linea Traguardo
Joshua Herrmann
Membro da: 16/04/2010
8 Reputazione
16 Guide realizzate
Cal Poly, Team 6-14, Maness Spring 2010 Membro di Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,090
