Strumenti
Nessun attrezzo richiesto.
Parti
Remove the back cover by placing your fingernail in the crease between the cover and the charging port. Pry upward and the cover should pop off easily. Pry upward and the cover should pop off easily.
  • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
  • Pry upward and the cover should pop off easily.
Aggiungi Commento
Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay. Now you are able to replace the battery with a new one. Now you are able to replace the battery with a new one.
  • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
  • Now you are able to replace the battery with a new one.
Aggiungi Commento
Conclusione
UMass Dartmouth, Team 1-9, Shastany Fall 2014 Membro di UMass Dartmouth, Team 1-9, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G9
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,797
