Introduzione
If the buckle or part of the wristband is damaged, it is a good idea to replace the bands on both sides so that they match.
Parti
Nessuna parte richiesta.
Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
  • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
  • Be prepared to apply some pressure with your fingers to perform the following action.
  • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
  • Grasp the exposed shoulder with the tweezers to perform the next step.
Is there a reason you are removing the straps before the back of the watch? They don't block the back from coming off or really get in the way much.
Andy Wickham - Replica
its in the way, obviously it need to take them off, lol.
silentg4real -
Where can I get this battery?
Josh Wheat - Replica
where can i buy a new replacement rear case? please let me know!
silentg4real - Replica
I'd like to know as well and don't care if it's a knock off either
Joseph Wellman -
This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband. Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
  • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
  • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
  • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
  • Repeat steps 1 and 2 for the other wristband.
Aggiungi Commento
Conclusione
Deja Miller
Membro da: 14/10/2014
438 Reputazione
3 Guide realizzate
USF Tampa, Team 2-5, Blackwell Fall 2014 Membro di USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 624
