Salta al contenuto principale
LG G Watch Display Assembly Replacement
Cosa ti serve
  1. LG G Watch Display Assembly Replacement, Wristband: passo 1, immagine 1 di 1
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Display Assembly Replacement: passo 2, immagine 1 di 2 LG G Watch Display Assembly Replacement: passo 2, immagine 2 di 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Display Assembly Replacement, Rear Case: passo 3, immagine 1 di 1
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Display Assembly Replacement: passo 4, immagine 1 di 2 LG G Watch Display Assembly Replacement: passo 4, immagine 2 di 2
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Display Assembly Replacement, Gasket: passo 5, immagine 1 di 1
    • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
  6. LG G Watch Display Assembly Replacement, Motherboard: passo 6, immagine 1 di 2 LG G Watch Display Assembly Replacement, Motherboard: passo 6, immagine 2 di 2
    • Use the spudger to gently lift up and disconnect the display connector.
    • Now use the spudger to disconnect the digitizer connector.
  7. LG G Watch Display Assembly Replacement: passo 7, immagine 1 di 2 LG G Watch Display Assembly Replacement: passo 7, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
    • Use the spudger to gently remove the motherboard.
  8. LG G Watch Display Assembly Replacement, Removing the screen: passo 8, immagine 1 di 1
    • Apply a small amount of pressure to the back of the LCD to create a gap for the opening pick.
    • Gently work the pick around the perimeter of the device to loosen up the adhesive.
    • An iOpener may be necessary to help loosen up the adhesive. Refer to our iOpener guide for info on how to use it.
  9. LG G Watch Display Assembly Replacement: passo 9, immagine 1 di 2 LG G Watch Display Assembly Replacement: passo 9, immagine 2 di 2
    • After using the pick to loosen the adhesive, simply pull the display assembly up from the metal bezel.
Conclusione
Altre 3 persone hanno completato questa guida.
Mandy McGarry
Membro da: 09/23/14
165 Reputazione
1 Guida realizzata
USF Tampa, Team 2-5, Blackwell Fall 2014 Membro di USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
5 Membri
9 Guide realizzate
4 Commenti
Where can you purchase replacement parts?
Brian Winebarger - Replica
Someone knows where to find a screen replacement?, i found at alibaba but i have to buy 1k ... :(
George Momo Seyssel - Replica
I found a 00 screwdriver was better than 000 for removing the motherboard.
Peter Jeremy - Replica
Be smart buy a used one for nuthin on eBay….
jeromedaues - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,373
