Salta al contenuto principale
LG G Stylo Battery Replacement
Cosa ti serve
  1. LG G Stylo Battery Replacement, Battery: passo 1, immagine 1 di 2 LG G Stylo Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure that you power off the phone before beginning.
    • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • There is a small slit that fits the plastic opening tool perfectly on the left side.
  2. LG G Stylo Battery Replacement: passo 2, immagine 1 di 2 LG G Stylo Battery Replacement: passo 2, immagine 2 di 2
    • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 11-7, Cheng Spring 2016 Membro di USF Tampa, Team 11-7, Cheng Spring 2016
USFT-CHENG-S16S11G7
4 Membri
14 Guide realizzate
Un commento
Thank you for your help. This has been making us crazy, your time is much appreciated.
Desi Young - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 61
Tutti i Tempi: 12,868
