Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling. Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
  • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
Aggiungi Commento
With your finger and from the bottom edge, lift the battery out of the phone and set it aside. You now have access to:
  • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
  • You now have access to:
  • Your SD card
  • Your SIM card
  • Your device's serial numbers
Aggiungi Commento
Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
  • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
Aggiungi Commento
Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing Pry the speaker assembly out of the phone and set it aside
  • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
  • Pry the speaker assembly out of the phone and set it aside
Aggiungi Commento
Conclusione
Brad
Membro da: 12/08/2012
1.800 Reputazione
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 213
