Salta al contenuto principale
LG Escape (p870) Headphone Jack Replacement
Cosa ti serve
  1. LG Escape (p870) Headphone Jack Replacement, Battery: passo 1, immagine 1 di 2 LG Escape (p870) Headphone Jack Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
  2. LG Escape (p870) Headphone Jack Replacement: passo 2, immagine 1 di 2 LG Escape (p870) Headphone Jack Replacement: passo 2, immagine 2 di 2
    • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
    • You now have access to:
    • Your SD card
    • Your SIM card
    • Your device's serial numbers
  3. LG Escape (p870) Headphone Jack Replacement, Loudspeaker Assembly: passo 3, immagine 1 di 1
    • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
  4. LG Escape (p870) Headphone Jack Replacement: passo 4, immagine 1 di 2 LG Escape (p870) Headphone Jack Replacement: passo 4, immagine 2 di 2
    • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
    • Pry the speaker assembly out of the phone and set it aside
  5. LG Escape (p870) Headphone Jack Replacement, Touch screen/digitizer: passo 5, immagine 1 di 1
    • Remove the remaining 6 screws securing the plastic frame to the back housing
  6. LG Escape (p870) Headphone Jack Replacement: passo 6, immagine 1 di 3 LG Escape (p870) Headphone Jack Replacement: passo 6, immagine 2 di 3 LG Escape (p870) Headphone Jack Replacement: passo 6, immagine 3 di 3
    • Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
    • Continue working your way around the phone, prying carefully with your prying tool
    • When you work the frame free, set it aside
  7. LG Escape (p870) Headphone Jack Replacement: passo 7, immagine 1 di 1
    • Wifi and cell service antennas
    • LCD connector
    • Back camera connector
    • Front camera connector
    • Touch screen/ digitizer connector
    • Charger port connector
    • Headphone jack connector
  8. LG Escape (p870) Headphone Jack Replacement: passo 8, immagine 1 di 3 LG Escape (p870) Headphone Jack Replacement: passo 8, immagine 2 di 3 LG Escape (p870) Headphone Jack Replacement: passo 8, immagine 3 di 3
    • With a spudger or safe open pry tool, carefully detach the LCD flex connector
    • Release the two antennae from their connectors
    • Release the back camera's flex from its connector
  9. LG Escape (p870) Headphone Jack Replacement: passo 9, immagine 1 di 2 LG Escape (p870) Headphone Jack Replacement: passo 9, immagine 2 di 2
    • Release the charging port flex from its connector
    • Release the front camera's flex from its connector
    • Release the touch screen/digitizer's flex cable from its connector
  10. LG Escape (p870) Headphone Jack Replacement: passo 10, immagine 1 di 1
    • Release the headphone jack's flex cable from its connector
  11. LG Escape (p870) Headphone Jack Replacement: passo 11, immagine 1 di 2 LG Escape (p870) Headphone Jack Replacement: passo 11, immagine 2 di 2
    • With a pair of tweezers, VERY carefully pull the volume button flex out of the rear housing
    • Repeat the process with the power button flex cable
    • The power button and volume button flex cables will tear very easily, so be cautious
  12. LG Escape (p870) Headphone Jack Replacement: passo 12, immagine 1 di 2 LG Escape (p870) Headphone Jack Replacement: passo 12, immagine 2 di 2
    • Lift the motherboard away from the housing, taking extra care not to snag any of the antennae or flex cables
    • Set the motherboard aside
  13. LG Escape (p870) Headphone Jack Replacement: passo 13, immagine 1 di 2 LG Escape (p870) Headphone Jack Replacement: passo 13, immagine 2 di 2
    • Insert a small flathead screwdriver or black plastic spudger between the front silver bezel and the black plastic mid-frame
    • Gently pry on the bezel to release the clips adhering the screen to the mid-frame
    • Work your way around the phone, still using the small flathead or spudger, until the screen is fully separated
    • Remove the screen, taking care not to tear the flex cable that is still threaded through the housing.
    • After carefully threading the digitizer and outer housing/bezel from the middle bracket you'll notice the digitizer is held on by a band of very strong adhesive - this will be destroyed when you take off the old digitizer. When you replace your digitizer you can use double-sided tape or epoxy to hold the new digitizer on the bezel.
  14. LG Escape (p870) Headphone Jack Replacement, Headphone Jack: passo 14, immagine 1 di 1
    • Peel the headphone jack's ribbon cable off of the mid-frame
    • The adhesive is very mild
Conclusione
Altre 2 persone hanno completato questa guida.
Brad
Membro da: 08/12/12
1.908 Reputazione
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,188
