Introduzione
Installing the Number Keypad and the LCD Screen can be done at the same time. Note, however, that the Keypad and the hardware casing are connected and must be installed together.
Place the phone so the screen side is facing down.
  • Place the phone so the screen side is facing down.
  • Locate the latch at the end of the phone, opposite of the camera.
Aggiungi Commento
Push/pull the latch away from the camera, causing the battery to pop out.
  • Push/pull the latch away from the camera, causing the battery to pop out.
Aggiungi Commento
Remove the battery.
  • Remove the battery.
Aggiungi Commento
Remove the 5 screw covers on the back of the phone using a Push Pin. Remove the 5 screw covers on the back of the phone using a Push Pin.
  • Remove the 5 screw covers on the back of the phone using a Push Pin.
Aggiungi Commento
With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
  • With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
  • Also with a Phillips #00 Screwdriver, remove the screw that was revealed once the battery was removed.
Aggiungi Commento
Open the phone. Open the phone.
  • Open the phone.
Aggiungi Commento
Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work). Prying open the part just to the left of the right hinge can be difficult.
  • Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work).
  • Prying open the part just to the left of the right hinge can be difficult.
  • Remove the back colored casing and set it to the side.
Aggiungi Commento
Gently pry and detach the connection located near the hinge with fingers. Gently pry and detach the connection located near the hinge with fingers.
  • Gently pry and detach the connection located near the hinge with fingers.
Aggiungi Commento
The circuit board and the key board will be attached, as shown in the second picture. Lift them both out from the rest of the phone.
  • The circuit board and the key board will be attached, as shown in the second picture.
  • Lift them both out from the rest of the phone.
  • Do not try to the detach key board pad from the circuit board. They are replaced as a unit.
Aggiungi Commento
After removing the circuit board and key board, separate the top part with the screen from the bottom part by detaching the hinges.
  • After removing the circuit board and key board, separate the top part with the screen from the bottom part by detaching the hinges.
Aggiungi Commento
Careful! The paint is easy to scratch.
  • Careful! The paint is easy to scratch.
  • Remove the 4 screw covers from top piece of phone by using a Push Pin.
Aggiungi Commento
Remove the four 3.44 mm screws that were under the covers using a Phillips #00 Screwdriver.
  • Remove the four 3.44 mm screws that were under the covers using a Phillips #00 Screwdriver.
Aggiungi Commento
Be careful while breaking the adhesive connecting the speaker and the casing in the following sub step so that you do not tear any wires. Pry open the colored casing using the Plastic Pry Tool. Remove the number pad and place it to the side.
  • Be careful while breaking the adhesive connecting the speaker and the casing in the following sub step so that you do not tear any wires.
  • Pry open the colored casing using the Plastic Pry Tool.
  • Remove the number pad and place it to the side.
Aggiungi Commento
Because the Number Keypad is attached on one side and on top of the outer screen, open its metal casing, in a "door-opening" manner. Because the Number Keypad is attached on one side and on top of the outer screen, open its metal casing, in a "door-opening" manner.
  • Because the Number Keypad is attached on one side and on top of the outer screen, open its metal casing, in a "door-opening" manner.
Aggiungi Commento
The pieces connected by wires are magnets and are removable.
  • The pieces connected by wires are magnets and are removable.
  • Remove the LCD Screen.
Aggiungi Commento
The Number Keypad and its metal casing are attached to the clear plastic screen that the LCD Screen was in. Replace both the Keypad and the casing as a unit.
  • The Number Keypad and its metal casing are attached to the clear plastic screen that the LCD Screen was in. Replace both the Keypad and the casing as a unit.
Aggiungi Commento
Conclusione
Nathan Farnum
Membro da: 05/04/2012
57 Reputazione
2 Guide realizzate
Cal Poly, Team 15-15, Forte Spring 2012 Membro di Cal Poly, Team 15-15, Forte Spring 2012
CPSU-FORTE-S12S15G15
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 939
